nitrous jet placement
RE: nitrous jet placement
For the wet kits, you want to have it after the MAF, but before the throttle body. Unless, of course, you have a plate kit that sits betwen the intake manifolds. Do you have a pic of your engine bay areund that area? Would make it easier to pick a spot.
im sorry, i dont have a pic availbale right now. so basically smack dab in the middle of the maf, and throttle body? its not a plate kit. its actually the dyno tune nitrous that i have been following your replys to posts about. i saw that you have the purge kit, and your budy has the actual kit. i have heard nothing but good about this kit. its just cheaper due to no middle man
If I was at home, I could take a better pic, but here is an opd picture showing how I have mine setup. You can see that i have it just after teh MAF, but just before the throttle body. As you can see in the pic, because of how I have my supercharger setup, i have very little room to actually place it.
Here's an older and crappier quality picture from before i had the nitrous and the supercharger. I just had a Cold Air Intake here. But I can show you where I could have placed it on this setup as well. I can place it anywhere in the red box, since it is behind the MAF (the black box) but before the TB. As you can see with the CAI setup, I have a lot more places that I could ahve drilled and installed it.
ORIGINAL: SSKiller
Technically it is not a jet. It is a fogger nozzle. The jets go in the fogger nozzle.
Here's a pic of what the jets look like (so you know when you figure out the size you need.) The size is usualyl stamped or written on the side of the jet. I'd show you how to place the jets in the nozzle, but again I'm not at home and can't take mine apart to show the pics. And obviouly you can't see it in my above pics because they are inside the nozzle.
