Dry/Wet Nitrous
RE: Dry/Wet Nitrous
dry only injects nitrous into engine, bumps fuel pressure to add more fuel through the injectors
wet injects a nitrous / fuel mix
purge gets the air outta the lines so you get more nitrous in
RE: Dry/Wet Nitrous
I believe that dry nitrous is nitrous by itself, and wet nitrous has fuel added to the mixture and generally makes for better performance gains. Purge valves are probably the greatest things since sliced bread. They remove any air within your nitrous feed line to ensure that you get pure nitrous the INSTANT you activate it. Whats more important to me are its looks. A musclecar purging nitrous delivers a dont-mess-with-me-ill-rape-you-any-time-any-day message for little children and professional racers alike. Great way to ensure instant performance and makes for a killer show stopper. [sm=icon_rock.gif]
RE: Dry/Wet Nitrous
ORIGINAL: Redline03GT
Half right.
second part= NO!!!!!!!!
Wet shot will not yield more power
Running Lean makes more power than running rich.
And it all depends on what you want to lay to the table and whatnot.
Wet kit's are good n everything, but Dry can do the same job.
RE: Dry/Wet Nitrous
Redline explained it correctly, dry is usually for 5.0s that can increase fuel pressure through the computer as nitrous is injected, wet more common and recomended for the late 4.6s because it taps into a fuel line and adds gas as nitrous is sprayed or your car will lean out and go boom. Both are safe when installed correctly, the purge removes liquid nitrous that pools in the unused lines that would otherwise cause a bog at launch, you want it in its pure gaseous state from the bottle.
RE: Dry/Wet Nitrous
ORIGINAL: Obsol3te
Half right.
Half right.
power comes from burning fuel, not air! the more fuel you burn correctly, the more power you can make in any given engine. the air is there just to provide the necessary oxygen to combust the fuel. a dry shot is only good up to the limits of the fuel system to add the extra fuel required to keep from running too lean and burning up the pistons. once you pass this point, which is about 50-75 HP on a normal 5.0, you have to go to a wet shot in order to provide enough fuel to keep the mixture from being way too lean!
and I thought you were finally beginning to understand all I've been trying to tell you too![:@]
and BTW, when you purge the lines, you are letting out gaseous N2O, not air! you want to remove the gas so that liquid is right at the solenoid ready to flash to the gas when the valve opens!
keep this up and I'll start a petition to revoke your mod privileges! LOL
RE: Dry/Wet Nitrous
ORIGINAL: roundman
WRONG WRONG WRONG WRONG WRONG WRONG
Esplain that one.
Why do you think nitrous is being injected into the engine in the first place?
More oxygen to burn
I understand what i need to
And if you're running nitrous and purging and LIQUID is comming out...
That's one VERY low pressured nitrous bottle
RE: Dry/Wet Nitrous
I have heard that running lean makes more power than running rich, but whether or not its true is besides the point - you do NOT want to run lean. For your 5.0 i would recommend an NOS dry shot, which they have on their website if youre interested.
