Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
belt slip problem on my procharger.
Old 11-19-2004, 11:43 PM
94GTNick
94GTNick's Avatar
Default belt slip problem on my procharger.
well i have tryed everything pretty much to get rid of belt slip, cant go to a smaller belt, bought a new tensioner, sprayed dressing on it(ranch). WEll nothing has worked, i was thinking about bead blasting my blower pulley because it seems to be the only pulley that is still slipery after spraying the dressing on it. but yeah i was wondering if anyone has a suggestion.
94GTNick is offline
Old 11-20-2004, 02:10 AM
Birdieman4
Birdieman4's Avatar
Default RE: belt slip problem on my procharger.
I had to sandblast my pulley for preventing slippage recently. It worked perfectly.
Birdieman4 is offline
Old 11-24-2004, 10:51 AM
Slo01cobra
Slo01cobra's Avatar
Check out Reichard Racing, he makes a pulley to help slip problems. If it is a 6-rib setup you can change out to 8-rib and that will help.
Slo01cobra is offline
Old 11-24-2004, 10:55 AM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
yes the RR pulleys don't usually slip
mdvaldosta is offline
Old 11-24-2004, 01:37 PM
chriscindy6369
chriscindy6369's Avatar
I use the traction spray for tires on my belt run i run the car Much less slipage then using belt dressing. I'm switching to 8 rib or Cog when i build the Motor
chriscindy6369 is offline
articman
06-21-2018 11:45 PM
10-07-2015 07:02 PM
Pyrate Dave
09-10-2015 07:30 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
09-08-2015 11:50 AM
Quick Reply: belt slip problem on my procharger.
