Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-04-2004, 08:15 AM   #11
FoxGT
Vehicle: unicycle
Send a message via AIM to FoxGT
Default RE: Pro Charger
Quote:
ORIGINAL: Redline03GT
Like Birdieman says - Kenne Bell Twin Screw is the best.
For low-mid RPM.
I thought that Prochargers with air to air intercoolers were better than Vortechs Aftercooler simply because the Aftercooler was air to water, which was not as efficient as the air to air... Could you please explain why the Vortech kit is better?
Air/water can be more efficent with just ice & no water cooler assembly, it takes away less psi when the air travels through it & cools it more depending on the size of both. Air/water is more of a low speed intercooler, like for if you live in a city & you are in alot of stop & go. Air/air is a good intercooler for higher speeds like highway driving.
A blower that is tapped into the oil supply will last longer, even though the oil for it is specifically for superchargers. However a supercharger with its own oil will offer a little more power.
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
FoxGT is offline   Reply With Quote
Old 12-04-2004, 12:24 PM   #12
mdvaldosta
I ♥ Acer
alot of folks also run Paxton intercoolers with the Vortechs instead of the aftercooler
mdvaldosta is offline   Reply With Quote
Old 12-04-2004, 12:35 PM   #13
me alot fast than u
I ♥ Acer
really how eff. is an air to air cooler?..not very.....
me alot fast than u is offline   Reply With Quote
Old 12-04-2004, 03:02 PM   #14
Birdieman4
For low-mid RPM.
Roots blowers are good for low-mid power. Twin screw blowers are good for low-high power. Isaac, don't you have a KB on your car?
__________________
02 S281E #60 R.I.P.
01 S281 #582 Procharged
http://www.ihra.com/profile/topfuel/rick_cooper.html
Birdieman4 is offline   Reply With Quote
Old 12-04-2004, 03:13 PM   #15
mdvaldosta
I ♥ Acer
air / water is more efficient... water is a much better conductor of heat - only prob with water is that it heat soaks fast
Old 12-04-2004, 04:48 PM   #16
Birdieman4
Quote:
Does the KB requires any regular service after install?
The only service required on a KB is making sure the self-contained oil in the blower stays full. Basicly it is service free. I never had to add oil to my twin screw ever, and I checked it regularly.
__________________
02 S281E #60 R.I.P.
Old 12-04-2004, 11:02 PM   #17
Valek
How do you change the oil in the ProCharger? Do I need to take it apart or does it has a drain or something
__________________
04 GT auto~SLP LT's, SLP X, Magnaflow catback, Diablo tune, 4.10's, TCI street fighter converter, Transgo shift kit, BBK intake, Accufab plenum and 75mm tb...
Valek is offline   Reply With Quote
Old 12-05-2004, 12:06 AM   #18
Birdieman4
It drains out from below and fills up on the top. There is a 1/2' screw cap that comes off for filling. It's really easy.
__________________
02 S281E #60 R.I.P.
Old 12-05-2004, 12:45 AM   #19
FoxGT
Vehicle: unicycle
Quote:
ORIGINAL: me alot fast than u
Very efficent at lowering temperatures, the problem is you lose pressure because of the path the air has to take.
Quote:
ORIGINAL: Birdieman4
For low-mid RPM.
Installed one on a friends car, never on any of mine. I'm not talking about how good they are unless you are referring to good as efficient. Roots are really efficient in low rpm, twin screw are really efficient in low-mid, & centrifugal is really efficient in high rpm. So a centrifugal is more efficent than a twin screw in higher rpm. Roots & twin screw are almost equal in efficiency in low rpm. & neither can rival the twin screw in mid rpm.
Quote:
ORIGINAL: mdvaldosta
As far as temperature cooling if you pack ice in with the water, an air/water is the most efficent, problem is when the ice melts. Air/air will will cool air more at higher speeds than the air/water. It is also more reliable, requires less maintainance, & cost less.
Air/water will cool air more at lower speeds, give better throttle response, have a lower pressure loss, and have less compressor surge. Air/water also doesn't require as much space, because it uses less plumbing.
__________________
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
Old 12-05-2004, 05:51 PM   #20
Birdieman4
...Well put, Isaac.
__________________
02 S281E #60 R.I.P.
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
