Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-11-2007, 10:14 PM   #1
drce500
Default how long does a 10# nos bottle last?
approx how long would a 10#nos bottle last in a stock type 4.6 gt,if you run it thru say 3d gear once in a while.im talking a good system like the noszle one.never had nos so i know nothing of it,thanks
drce500 is offline   Reply With Quote
Old 07-11-2007, 10:53 PM   #2
moosestang
Default RE: how long does a 10# nos bottle last?
It depends on the size of the jets, but i've read 10 seconds per .8lbs of nitrous. Let's just simplify it and say for every 12 seconds you are spraying, you use up 1 lb of nitrous. So according to my calculations you could spray for 2 minutes straight with a 10lb bottle.
__________________
Boost or Buell, decisions, decisions.
whipple HO SC,FRPP springs, Pypes mid mufflers, hurst, 4.10's, J&M extreme joint lca's, adj. UCA, relo bracets, 1 piece DS, spec stg 2 clutch. Accel coils 12.52@117.6mph so far with a 2.01 60 ft time(pre shaft, coils, clutch).
Downshifting Crew Member
moosestang is offline   Reply With Quote
Old 07-12-2007, 01:34 PM   #3
Dingo0079
I wouldn't be going to run the magic mile with nitrous though, not all the time any way. My bro 12lb bottle with 100 shot lasted approx 10 runs at the strip.
__________________
2001 GT Dark Green
KB 2.1L intercooled @ 9 PSI, bunch more stuff from Steeda. 12.57 @ 112.5 Street tires.
Dingo0079 is offline   Reply With Quote
Old 07-12-2007, 04:50 PM   #4
nitrous_bob
nitrous_bob's Avatar
Vehicle: 1993 notch
those numbers sound about right
w/ 80 jets and squirting out of the hole and all the way down i get 10 full passes b4 i need a refill, which is actually about 7 lbs, you lose too much pressure after that so every time you fill...your not getting 10 lbs, just about 6-7
i would say you'd getsomething like (20) 6 second blasts out of it as long as you keep it warm, but thats a guess
__________________
'93 calypso notch 6th stang and counting
nitrous oxide is proof there is a GOD and he wants us to be happy
http://www.myspace.com/nitrous_bob
nitrous_bob is offline   Reply With Quote
10, 10lb, 10lbs, boost, bottle, craigslist, dimensions, last, lasts, lbs, long, nitrous, nitrouse, nos, oxide
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
