View Poll Results: A poll
PowerDyne
0%
BBK
0%
Eaton S/C
0%
Voters: 65. You may not vote on this poll
KB vs. Other S/C's...POLE!PICK your FAV.
#61
RE: KB vs. Other S/C's...POLE!PICK your FAV.
ORIGINAL: 50FastFord
Okay I been wonting to add a KB to my 99 Cobra, but I also been hereing that S/C such as Pro-Charger add more horses, those are Centrifugal Superchargers, What is the difference, Which is better for daily driving, I looking for 9psi-10psi,, Which S/C for the msot rwhp numbers is the best for the price.
The strength of the Vortech is on the highway. The surge from 60 mph to 130 is incredible. You will get there quick. Launching is a different story. All is normal until you hit boost at 3100 rpm. That is when all Hell breaks loose. Tires start spinning again. You will need a set of Steeda lower control arms, and welded Subframe connectors to help with that. A nice set of yellow Koni adjustable shocks will not hurt too. I went with that set up along with an Auburn limited slip 28 spin gear, 3:73's, and BFG Drag Radials (275x40x17) my QM times are a respectable 12:13.
No complants on the Vortech.
#62
I love my KB. On the stock motor and 9 psi I had 389 ft-lb @ 3400 rpm, 390 rwhp @ 5200 rpm.
Ran it for a few weeks and went in for a COMPLETE rebuild. I'm into this project foe way more $$$ than I ever expected, but it's my mid-life crisis car, so WTF! I go 60-90mph in about 3 seconds with the top down.
Setting up a KB correctly requires a really good tuner. If you go over 9 psi, plan on ugrading to an 8-rib belt... and about 1200$ in pulleys.
Foe a street car, the only reason not to go KB is $$$.
Cheers.
Cheers.
#65
ORIGINAL: jacrockett
Birdi,
Wanna race?
0-60?
60-90? ... I'll win with my top down.
Any speed yo want... my KB has done me well! You just have to build the right setup.
Birdi,
Wanna race?
0-60?
I'd race you... If it were possible.
#66
Birdi,
Wanna race?
0-60?
Wanna race?
0-60?
#67
i say kenne bell all the way! go centrifugal and expect a cracked intake manifold. my common sense tells me high pressure in a plastic manifold is bound to crack sometime. so why not spend the little extra money and get a whole new manifold with a blower on top of that.
#69
ORIGINAL: TheBob98GT
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
