Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Whats everyone's setup?
Old 07-24-2007, 10:02 PM
Quicktime_GT
Quicktime_GT's Avatar
Default RE: Whats everyone's setup?
stock engine
Procharger P1sc @10psi
Procharger 3 core intercooler
full length headers, mac o/r prochamber
255lph svt focus pump
42lb injectors
pro m mass air meter
bbk throttle body
mossy oak air freshener
sct tune by speedy dyno
dynojet #s 395rwhp 435rwtq
20 degrees timing at wot
12~ -1 a/f think i'm going to go a little richer to be safe
Quicktime_GT is offline
Old 07-25-2007, 12:40 AM
turbosha
turbosha's Avatar
turbosha is offline
Old 07-25-2007, 12:43 AM
turbosha
turbosha's Avatar
ill also be sport'in the 331 and twins
turbosha is offline
Old 07-25-2007, 12:46 AM
turbosha
turbosha's Avatar
turbosha is offline
Old 07-25-2007, 12:49 AM
turbosha
turbosha's Avatar
mine hasent made it to the machine shop yet!!!
turbosha is offline
Old 07-25-2007, 01:59 AM
tbirdscwd
tbirdscwd's Avatar
Stock motor
Procharger P-1SC @ 5-6 PSI
2-core intercooler
42lb injectors
270lph Aviator pump
SCT 90mm Blow-though Maf
Trick Flow Track Heat Intake
BBK 75mm Throttle body
Borla Catback Exhaust
Diablo Tuning by RWTD
Dynojet 361rwhp 353rwtq
tbirdscwd is offline
Old 07-26-2007, 05:03 PM
uedlose
uedlose's Avatar
Wife's car the old set up is now gone with the new gone on. the old was 306 long rod motor R-block Eagle Forged crank Scat H-beam Rods,JE custompistons with tool steel pins.ported TFS TW heads Edelbrock ported intake RPM, Anderson B-41 cam.P600b pro charger with a 17psi pulley only made 10 psi at the intake.C-4 3500stall 373rear gears full weight street car. Coupe, no HP numbers but ran10.99 and 124 MPH with a split boot at the the intercoolerthats why it only was making 10psi didnt find this till I was taking it off cuz. I sold it. OH Well you live you learn..... new set up is the same with less gear and less cam anda 80MM turbo hoping for low10s anything more then that is just icing on the cake
uedlose is offline
Old 07-26-2007, 05:44 PM
GearJammer78
GearJammer78's Avatar
I got nothing special;
3.73 gears
Magna flow exhaust
Proline springs
KB 2.1L int 9# boost
I cannot get to a dyno till mid August so I dont have the HP numbers yet. KB claims 410 Peak RWHP and 425 flbs torque. We'll see?
GearJammer78 is offline
Old 07-26-2007, 07:15 PM
luckythirteen13
luckythirteen13's Avatar
here is a moch up of my soon to be setup. i wanted to see if i had enough 3" piping for the intake.
luckythirteen13 is offline
Old 07-26-2007, 08:53 PM
mark007
mark007's Avatar
waiting to be installed. stroked and blown 302.
mark007 is offline
Quick Reply: Whats everyone's setup?
