Max Safe shot for 514 600 hors
What would be a safe shot for ford racings 514 stroker withEagle H connecting rods 9.8:1 compression forged aluminum dished pistons with full floating pins, machanical roller cam 647 " lift cobrajet aluminum or super cobra jet aluminum heads. 72cc, victor junior intake, dominator carb????????????</P>
200safe ponies?</P>
Two hundred shot is plenty safe,I've heard several guys running 300.I hope you have lots of tire in the back!<IMG src=smileys/smiley2.gif border="0">What's the car going to be used for,street or track?
I'd say start around 250. But you might won't to go with a dual stage setup. Go with a plate system for off the line and then use a direct port shot to really get the car moving. This help put lots of power to the ground without blowing the tires right off the line. Theres a lot of other stuff you'll need; fuel pumps, timing retard, and when you get into using bigger shots, you'll go through the juice alot faster. So, maybe two bottles to keep the party going.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 11:50 AM
