Bypass valve vs. BOV
RE: Bypass valve vs. BOV
Thats awesome. I might look into that for my setup this winter. Is there a bennefit to venting as opposed to recurculating the air? Oh and btw... you car sounds AWESOME, I love that whine it has.
ORIGINAL: SlvrOhTwoGeeTee
So basically it was done just to clean up teh engine bay, and it was done when I relocated my air filter to pull in cooler air. But like I said, that bitch is LOUD when in the higher RPM range. I may see if I can quiet it down a bit
I have a regular procharger bypass blowing off into the air with a blow through mass air meter. Opposite of what was said earlier you actually have to run a blow through mass air if you blow off into the air, with a draw through mass air you have to recirculate.. .
Here is a video of me jackin around.. you can hear it every now and then here...
http://s37.photobucket.com/albums/e8...current=me.flv
