i'm curious where you're spraying?Â* i sprayed mine before the TB.
If your talking about the Mr. Freeze I do not have my hooked up yet. I am getting it. Only 90's has it hooked up. The directions says make it at the elbow or inlet pipe as close as you can so to sprays towards the supercharger.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
1992 5.0
ford crate motor
b303 cam
bored .30 over
3:73 Gears
318 at the flywheel
off road x pipe
trickflow intake
trickflow heads
1.6 Rockers
6.8 pushrods
24 lb injectors
Mass Air
lowered
i'm curious where you're spraying? i sprayed mine before the TB.
If it's the Mr. Freeze kit then you really have no choice as to where to put it. There's no pump or anything like that. So it has to be close to the supercharger impellers. The mixture gets pulled through the fast-spinning blades of the impellers, which atomizes the mixture and sends it on its way through the tubing.
Also keep in mind that you could run into problems if you have an intercooler installed and are using the Mr. Freeze kit that will spray methanol and water through it.
__________________
Car @ idle
NOS is like a hot chick with an STD. You wanna hit it but you're afraid of the consequences.
Yes...Mr. Freeze has to be hooked into the intake elbow on the back sideof the blower...it injects before the supercharger and as samseed says...the impellers draw the Meth through the system..If you look at the black inlet tube that comes from the fender to the back of the supercharger...that is where my Meth goes...right behind the supercharger at the elbow...
The Snow Kit is installs after the superchargerand before the throttle body... (it would be drilled/installed into the intake tube that says Vortech)
Yes...Mr. Freeze has to be hooked into the intake elbow on the back sideÂ*of the blower...it injects before the supercharger and as samseed says...the impellers draw the Meth through the system..If you look at the black inlet tube that comes from the fender to the back of the supercharger...that is where my Meth goes...right behind the supercharger at the elbow...
The Snow Kit is installs after the superchargerÂ*and before the throttle body... (it would be drilled/installed into the intake tube that says Vortech)
Awesome thanks for the Visual that helps. Where di you hook the vacuum up at, and what is the line that is plugged into the right side of the supercharger when you are looking at the pic. What is that hose that looks like it is coming under your hood look like it is head up towards your windshield?
__________________
1992 5.0
ford crate motor
b303 cam
bored .30 over
3:73 Gears
318 at the flywheel
off road x pipe
trickflow intake
trickflow heads
1.6 Rockers
6.8 pushrods
24 lb injectors
Mass Air
lowered
