Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-02-2007, 10:47 AM   #1
jmonda
Default I know this IS a Stupid Question BUT
Ok I am definitely not familiar with a supercharged engine. I have a 98 4.6 with the vortech supercharger 5 speed manual tranny. Here is the dumb question part. At how many rpms should I be shifting. If I am racing should I take it up to 5500 or more? If I am just driving around should I shift at like 3 grand?
__________________
1992 5.0
ford crate motor
b303 cam
bored .30 over
3:73 Gears
318 at the flywheel
off road x pipe
trickflow intake
trickflow heads
1.6 Rockers
6.8 pushrods
24 lb injectors
Mass Air
lowered
jmonda is offline   Reply With Quote
Old 10-02-2007, 10:54 AM   #2
nanaki
Retired MF Moderator
Default RE: I know this IS a Stupid Question BUT
i wouldn't go above 6 grand. your car probably levels out around 5500-5700 and stops making power or may even start to lose it. best to shift around there. my car fell on it's face at 5700rpm with the S trim i had on there.
__________________
2004 Mustang GT - SOLD!
2009 Nissan Altima Coupe 3.5 - stock
2007 Pontiac Solstice GXP - GMPP reflash
2007 Corvette - Boltons, Vortech, etc
nanaki is offline   Reply With Quote
Old 10-02-2007, 11:41 AM   #3
jmonda
Quote:
ORIGINAL: nanaki
i wouldn't go above 6 grand.Â* your car probably levels out around 5500-5700 and stops making power or may even start to lose it.Â* best to shift around there.Â* my car fell on it's face at 5700rpm with the S trim i had on there.
Wow ok I have been taken it to 5500 pretty regular I guess I better rethink that.
__________________
1992 5.0
ford crate motor
b303 cam
bored .30 over
3:73 Gears
318 at the flywheel
off road x pipe
trickflow intake
trickflow heads
1.6 Rockers
6.8 pushrods
24 lb injectors
Mass Air
lowered
Old 10-02-2007, 11:48 AM   #4
tripsevn7
Moderating with Angels
Send a message via AIM to tripsevn7
as long as your not over revving the car, i.e. what nanaki said about running up over 5700 your fine. the harder you run her on a consistent basis equals how long she will last. if your putting your foot thru it at every light and what not, be prepaired to start wearing parts out. also you may want to add your mods and vehicle description to your sig, that way you will not have to type it out every time you post.
__________________
tripsevn7 is offline   Reply With Quote
Old 10-02-2007, 12:01 PM   #5
jmonda
Quote:
ORIGINAL: tripsevn7
as long as your not over revving the car,Â* i.e. what nanaki said about running up over 5700 your fine.Â* the harder you run her on a consistent basis equals how long she will last.Â* if your putting your foot thru it at every light and what not,Â* be prepaired to start wearing parts out.Â* also you may want to add your mods and vehicle description to your sig,Â* that way you will not have to type it out every time you post.Â*
Yeah duh thanks for the advice I guess I should add them.
__________________
1992 5.0
ford crate motor
b303 cam
bored .30 over
3:73 Gears
318 at the flywheel
off road x pipe
trickflow intake
trickflow heads
1.6 Rockers
6.8 pushrods
24 lb injectors
Mass Air
lowered
Old 10-02-2007, 12:03 PM   #6
only90s
Hey jmonda did you ever put that car on the dyno?
__________________
90 GT, 5spd, 4.10s, Vortech 10lbs, 308 Twisted Wedge, TFS Stage 1 cam, Holley Systemax, 42lb injectors, Power Pipe, SCT Chip 461rwhp/434rwtq..
90 Notch-Paxton, 355 gears, flowmasters-sold 9/94
only90s is offline   Reply With Quote
Old 10-02-2007, 12:16 PM   #7
jmonda
Quote:
ORIGINAL: only90s
Yeah I sure did. I had it Dyno tuned is actually 297 rwhp air to fuel 11.3. I would like to get more horse the mechanic tells me to up the psi. Not sure what to do.
__________________
1992 5.0
ford crate motor
b303 cam
bored .30 over
3:73 Gears
318 at the flywheel
off road x pipe
trickflow intake
trickflow heads
1.6 Rockers
6.8 pushrods
24 lb injectors
Mass Air
lowered
Old 10-02-2007, 12:18 PM   #8
only90s
Quote:
ORIGINAL: jmonda
Quote:
ORIGINAL: only90s
How many pounds of boost is it putting out?
__________________
Old 10-02-2007, 12:29 PM   #9
jmonda
Quote:
ORIGINAL: only90s
Quote:
ORIGINAL: jmonda
Quote:
ORIGINAL: only90s
The guy said it was at 9psi He said the easiest way and cheapest to ad some HP would be go more. I asked him about doing a pi intake swap and he did not think it would do any good. I looked at intercoolers but man they are way up their as far as price. Was thinking about doing a TB and Plenum. Not sure
__________________
1992 5.0
ford crate motor
b303 cam
bored .30 over
3:73 Gears
318 at the flywheel
off road x pipe
trickflow intake
trickflow heads
1.6 Rockers
6.8 pushrods
24 lb injectors
Mass Air
lowered
Old 10-02-2007, 12:43 PM   #10
tripsevn7
you may want to look into meth injection as well. snow makes a good kit which will free up a couple ponies. the tb and plenum arent bad ideas, but i would look into opening up the exhaust as well.
__________________
anderson, freeze, hurting, impeller, mr, vortech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
