Turbo or Charger?
RE: Turbo or Charger?
ORIGINAL: nathansmith50
one other benefit of turbo is you can have 2 of them.
And there is a noticable difference in power loss from a Turbo and S/C
Believe in January's MM&FF they tested each form of boost(except nitrous) on an 03 Cobra.
All running around the same boost levels.
The turbo took the cake, BY FAR around 120+ more ponies from like 14psi?
Can't remember exactly, but if you really care to know I'll look at the mag for ya and post the #'s
ORIGINAL: Obsol3te
Single Turbo=More Power
with 5 psi on an intercooled turbo you will make more power than with an 8 psi intercooled supercharger. and turbo lag is now myth thanks to technology. go with the turbo and whoop up on every one. i wouldgo with 3.73 gears as well as a higher stall torque converter
Yea, MM&FF had a twin turbo setup vs vortech vs kenne bell, and turbo put down most power. YinYang- if you run a single turbo on a V8 you have a crossover pipe which connects the 2 headers, so only 1 pipe is feeding the turbo. 3.73s may be alright with an automatic, but nothing higher on a turbo setup, or you'll find urself running out of gear.
people talk a lot about the parisitic loss of superchargers. i.e. the loss of power that it takes to turn the screws. but the fact remains that the power you're losing is so minimal, maybe 5 horse, compared to the horsepower you can gain. kenne bell makes a kit specifically for the '96-'04 GT 4.6 that'll give you an extra 262hp for a total of 507. turbo or supercharger? pretty much moot. you get about the same effect from both. anymore the difference is minor.
ORIGINAL: YinYangStang
So a single turbo on a V8 gives more power than dual turbos? Do you just leave the other side of the exhaust un turboed, or is there something you have to do to balance the pressure?
ORIGINAL: Obsol3te
ORIGINAL: matthockey32
ORIGINAL: Birdieman4
With stock engine internals there is zero reason to do turbos. Period.
An automatic works well with a turbo in that you don't lose all your boost pressure between shifts and you can build boost off the line by power braking. So you really shouldn't worry about having an auto. I also wouldn't worry about turbo lag at all on an engine that size. Its your call. Supercharger seems to be the popular and easy bolt-on solution for N/A cars. Turbos themsleves are quite cheap and can be upgraded and have boost levels changed very easily. Though having the ability to raise your boost levelst by a flick of a dial can tempt you to push levels higher then you should.
