Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Supercharger or turbo?
Old 04-07-2008, 12:20 PM
snowboard49dude
snowboard49dude's Avatar
Default Supercharger or turbo?
I have been looking into buy a supercharger and I dont know what to get. Which one is the better performer? And if I decided to get one, which kind should I get?
snowboard49dude is offline
Old 04-07-2008, 01:07 PM
tws1098
tws1098's Avatar
Default RE: Supercharger or turbo?
IMO you will have more potential out of the Turbo but the S/C will be a decent bit more reliable. I would go with the S/C unless it is not a daily driver. From asking a similar question I would recommend Kenne Bell if you want a twin screw and Vortech if you want a centrifuge. JMO.
tws1098 is offline
Old 04-07-2008, 04:08 PM
bighungrymatt
bighungrymatt's Avatar
Procharger is nice
bighungrymatt is offline
Old 04-07-2008, 06:55 PM
floodzilla
floodzilla's Avatar
GO TURBO!! more power, more torque and easyier to adjust to what you want. of course im a little partial. it really comes down to budget and personal preference. but before you do either, dont forget to add fuel system upgrades into your price.
floodzilla is offline
Old 04-07-2008, 07:07 PM
Frostbitten
Frostbitten's Avatar
someone said superchargers were more reliable than turbo???[:@]
Frostbitten is offline
Old 04-07-2008, 09:09 PM
Fobra
Banned
Fobra's Avatar
.. yea they are in alot of ways, mostly tuning - but if setup right /used right the turbo is more reliable - but for consistancy the s/c wins
Fobra is offline
Old 04-08-2008, 04:43 AM
FoxGT
FoxGT's Avatar
I personally prefer turbo. Superchargers are more reliable though, but if you understand what's going on turbo's are plenty reliable & you can easily make it outlast the engine. The fluid bearing turbos aren't too expensive to rebuild either. I've never tried rebuilding a ball bearing turbo, but both the shop i buy my rebuild kits from & the one i buy my flanges from say it's expensive & to my knowledge it's hard to find places to rebuild it (but i've never tried). Either way though, if maintained properly a ball bearing turbo would still outlast the engine. oil changes on time, letting the engine warm up to operating temp (or turbo rather) before getting on it, & letting it idle for a bit before shutting it down (turbo timers are handy for that) to prevent coking. Those kinds of things if over looked can damage the turbo early.
FoxGT is offline
Old 04-08-2008, 07:48 AM
Fobra
Banned
Fobra's Avatar
+1 for ceramic ball bearing
Fobra is offline
Old 04-08-2008, 08:37 AM
snowboard49dude
well I drive my mustang close to everyday, unless if its wet then I dont drive it. But I want something that gives me alot of power and at the same time reliable enough to not screw me or my engine over; ie: having to rebuld anything.
Old 04-08-2008, 09:33 AM
OneFastEclipse
OneFastEclipse's Avatar
It's nothing to do with the reliability of the actual turbo compressor itself. In terms of compressor reliability, a turbo can easily see 100,000+ miles without even a hiccup as long as it is properly maintained. The things to watch when turbocharging your mustang are mainly if you see drastic changes in your local climate. Up here in Ohio, it is very easy in the summer for it to be 90 degrees one day, and 65 degrees the next. Drastic changes in temperature can cause drastic changes in your turbos performance. It can create boost spike or even boost creep(usually that is due to other things) which could be detrimental to your engine. There are ways to tune around it but that means you have to be overly conservative with your tune and not see your maximum potential, unless you have a way to watch your a/f ratio and modify your tune each day.
Both superchargers and turbos have their ups and downs. It's all a matter of how you want to play and sound. Either one will make you fast as hell, both sound and operate very different.
OneFastEclipse is offline
Quick Reply: Supercharger or turbo?
