stock 5.0 with 15 psi s trim?
What would a stock 5.0 with a s-trim non intercooled at 15 psi make to the wheels i am guessing around 380-430
Also how much HP can the hypermax pistons take? i want to make 500 rwhp on the stock block.
RE: stock 5.0 with 15 psi s trim?
ORIGINAL: abmtex2007
People have done more then 15psi on the stock block. It's doable but I would seriously recommend some kind of cooling. Preferably methanol injection. It's all in the tune. If your running around on the stock E7 heads, 500rwhp is not going to be easy, even on 15 psi. Put aftermarket aluminum heads on there with about 10psi and you'll see your 500rwhp pretty easily.
