supercharging an 89 5.0 CAMS?
I am going to run 11 lbs of boost on a 5.0. will i need to get an new cam with different lift or anything at all?
i know i need larger injectors and a few other things, but i need to know if i can run with the stock cam and possibly make 400 hp?
thanks
thanks
RE: supercharging an 89 5.0 CAMS?
Can you run a stock cam with a supercharger...YES. Can you run a stock ehaust and a supercharger...YES. Is it recommened to do either for FI....NO! Remember that the stock cam was set up for a N/A 5.0 not a supercharged one. If you want the best results, get a cam designed for a supercharger 5.0 and a good tune. Lift is not as important as duration and LSA when dealing with a supercharger. FYI Also for me the type of supercharger ie roots, centi will also very the cam depending on the goals of the car. The only time you can get a way with using a N/A cam and a power adder is with the sauce.(N2O) Unless the car is only a track car.However I stillspec outthe cam a little different. In both situations. Good luck in reaching your goals.
ORIGINAL: marlfox8
thanks
thanks
ORIGINAL: Turbo5point0
Im planning on runnin a turbo with 450hp on the stock cam
I'm not saying it wont work... it will work plenty fine, but it's not good if you're looking for getting a lot of power.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
