Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
wideband and window switch ?
Old 07-10-2008, 08:03 AM
68wicked
68wicked's Avatar
Default wideband and window switch ?
Ive been looking at getting a wideband gauge, and have been getting a little mixed up with the difference between a wideband and just something like a A/F monitor. I still havent gotten back to the states to get it tuned but from what ive heard ill be fine untuned. I just want that piece of mind that im not running lean. Also i purchased a zex window switch any one have any tips on installing it ive read the install manual online and im clueless on where to get a tach signal on our cars.( i suck with wireing) Thanks in advance for helping out
68wicked is offline
Old 07-10-2008, 10:28 AM
FoxGT
FoxGT's Avatar
Default RE: wideband and window switch ?
air/fuel monitor is referring to the gauge. There are multiple parts to a wideband setup. There's the wideband o2 itself, the wideband controller, then the optional gauge.
Some kits don't come with gauges. Make sure you get a digital gauge, not the led bar type. Summit makes a good kit that uses the lc-1 controller, bosch o2, & a summit gauge for $250. AEM 6in1 is pretty good aswell, it uses the led & digital #'s helpful so you can see if you're running lean out of the corner of your eye.
FoxGT is offline
Old 07-10-2008, 04:00 PM
68wicked
68wicked's Avatar
Hey thanks so summit sells the whole kit for 250 most kids ive seen are around 400 im going to have to check that out thanks
68wicked is offline
Old 07-11-2008, 12:12 AM
FoxGT
FoxGT's Avatar
Another plus is it has two outputs. So you can just thread the wideband into the stock o2 position & program one output to the factory narrowband voltage settings, then the other output going to the gauge you can program to give you a wideband reading.
FoxGT is offline
Old 07-13-2008, 05:20 AM
68wicked
68wicked's Avatar
ok so now i have a little problem i ordered the AEM ugeo wideband but now ive come to realize that ive got 2 cyl banks would i be ok with just mounting the 1 sensor on one header or would i need to somehow rig two one for each header?
68wicked is offline
Old 07-13-2008, 06:27 AM
Nawzzz
Nawzzz's Avatar
Mount it on the side cylinder one is, I think it's the passenger side.
Nawzzz is offline
Old 07-15-2008, 02:54 PM
FoxGT
FoxGT's Avatar
One bank is perfectly fine. This is to get a general idea of the a/f ratio of the entire engine. Obviously your eec isn't going to dump more fuel into the left bank (on purpose) than the right.
The only thing having more than one is good for is telling how that certain side or cylinder is running. You can go as far as putting 8 on it to see how each individual cylinder is running.
It doesn't matter what side you mount it on. On other peoples cars I generally mount it on the passenger side & run the conroller wires up through the passender floorboard, Then I mount the controller by the eec. But with the aem, the gauge is the controller. If you're mounting the gauge on the drivers side you may be better off using the drivers side bank, then run the analog output to the stock eec & program it to run the factory a/f ratio/voltage settings, this way you can just take the narrowband o2 out & plug the wideband in.
One thing... Make sure you have a leak free connection otherwise the o2 will read that you're running lean. That may also be an issue if you've had trouble getting one side to seal.
FoxGT is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
PaulH2
20
01-31-2016 09:48 AM
guitarman376
09-30-2015 05:54 PM
DreadPirateRoberts
09-26-2015 02:11 PM
Quick Reply: wideband and window switch ?
