CAM Question?
CAM Question?
I traded in my 98GT for a 03 GT i have a BBK CAI, Bassani Offroad X Pipe, Flowmaster Catback exhaust. A guy i work with says he has a set of Stage 3 Comp Cams for my pony with springs, i believe, that he will sell to me for $500-$600. The question i have is what else would i need to make a cam install possible and about how much money for each part or kit to make this happen, i know he mentioned i needed a stall converter, but what else is needed i want to get these installed within the next month. If any one can help that would be greately appreciated, Look forward to hearing from you guys.........
RE: CAM Question?
I'm not sure about the NPI cams, but I know the stage 3s for a PI engine usually require notched pistons for PTV clearance. Also most people will probably tell you that without a forged motor, you're not really getting the power out of that cam that you should. The powerband of most stage 3s is higher in the RPMs than a stock block should be pushed.
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
