cms stage 3 blower cams
RE: cms stage 3 blower cams
is this a cammer motor or is it a push rodmotor? What heads you running if its a push rod motor. I am not real up on the cammers but they sound a bit big if it is a cammer to me.
Try posting this up in the 4.6 General Discussion section. Chances are you'll get alot more answers alot faster, and there's alot of really good guys to talk to about potent mod motors.
Just give Cushman a call. They can tell you if it will work for your setup or if its too much. As far as idle and all that you'd be fine on the street since blower cams have a much less agressive idle than N/A cams. I know other companies that offer stage 3 cams often say they require your engine to be bored .030 over. You'll definitely need new valve springs and those cams would probably be a waste without ported heads. You can also try PMing 10"Terror, he is the owner/operator or whatever of Cushman Motorsports.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
