100 shot with no tuner will it be ok?
when i bumped the timing to where it should have been the hole time it "blew"
im down to the head bolts, and the heads will be off, so here in about an hour, ill have em off and see if theres any damage there, but im guessing theres gonna be no sign of anything wrong under there.
my intake gasket was blown in 3 places, and the lower intake gasket was a cheap cork gasket with TONS and TONS of RTV gasket sealer, i know your sapposed to put a "think bead" but who ever put this on, put way to much.
so my guess is the extra pressure from the timing just poped the intake gasket, poped a hole in the side of the vacuum tree too!
parts are on the way, car should be back together in 2wks.
thx for asking, and good luck with yours!
my advice would be not to be scared of the juice, maybe if its your daily driver, i have 2 other vehicles so i dont need to worry about the mustang being down for a mth.
put your base timing a 8*, run highest pump octane you can get, get 1-2 step colder plugs (1 should be fine) upgrade your fuel pump (welbro 190pump is fine) make sure your fuel filter is pretty new, and SPRAY IT FOR 100!!
http://www.youtube.com/watch?v=N5d3VQ0k4SU
thats my video of me spraying 100shot with 0* - +2* base timing.
sorry for the side track of your thread OP
i think that you are talking about a window switch. its not a switch hooked to the windows it hooks to a coil and reads the rpms. You set it to come on at a certain rpm. and the switch that goes to the pedal really goes on the throttle body and tells the system when you are at wot
the 87 tune will pull some timing but like he said you need to run premimum fuel. I have been spraying 50 right now till i can get a few more things like a window switch fuel pressure and low pressure cut off but the 50 runs hard i pull above 3k and only in 2nd 3rd and part of 4th letting off at around 5500rpm
worried about traction in first is the only reason that i dont spray in 1st it is hard enough to gas it hard at the top of first with no spay and to keep traction but i do have crappy tires and not much as far as suspension mods
i have 4.10's and was spraying my 100shot in first gear, not even warming the tires.
(spun sometimes, but only say once out of every 5 times)
stock suspention, convertible even (vert fox's flex like crazy) just some good ol' micky thompson ET street radials at 30psi
jwog666
12-27-2021 08:09 PM
