H-pipe with SLP LoudMouth I
ok guys so this is prob a highly talked about topic and i know everyone gets tired of it but i need to know if anyone else is rocking this setup...
I want to do stock manifold > H-pipe > and SLP LMI
does anyone else have this and can they tell me how it sounds or if there is a video around...
I had the setup with an X-pipe and it was loud which is good.. but i couldnt drive it normal without hitting rasp... i have heard that an H-pipe will take that rasp note out?
any opinions would be apreciated...
What do you mean machine gun? i thought H was supposed to give it more of a low mellow sound instead of the X which sounds like a mix of machine gun / nascar... and the LMII mufflers arent much different then the I's.. i thought about doing powerflo mufflers to quiet it down...
I would go for a catted H if you keep the LM1's. If you want to go o/r then I would pick up some LM2's.
yeah and on deacceleration it will sound mike a m16. its awful i had an o/r h and magnapacks, then slp lm1 and prochamber which actually sounds pretty good, but now i have bassani catback with pypes x and love it. it your going to keep the lm1's i suggest going with a prochamber, no pop or rasp
quick question what type of h is it cause i spent like 2000 plus dollars on exhaust till i found 1 i liked which prolly should have been my first choice
i also made some exhaust clips so msg me if i dont check back
