supercharger problems
on the inside of the head unit or on the outside. if it is on the inside it sounds like a bad seal to me. If it is on the outside check to see if the oil feed line has a hole in it or maybe the return has a hole in it.
no its on the inside some how spraying down the outlet pipe didnt even notice it i just hooked the belt on an startet it sounded sick didnt even notice till i dropped a wrench an saw the oil all over the ground .
quite a few prochargers had the problem with the front seal failing not too long after install due to seal material used. You could either send it off & have them do it or go to google & search for: procharger front seal. Quite a few people have the problem, so you should be able to find how some people fixed it.
Galactic
04-29-2019 02:56 PM
ernesto-619
09-10-2015 01:32 AM
09-03-2015 07:14 PM
