methanol/water kit?
methanol/water kit?
hi guys! i was thinking of getting the meth kit on my 98cobra procharged with 8lb/3.60pulley 3core intercooled, will the kit help me gain lots of power, since i was planing on getting more boost with a 3.30 pulley?
You probably wont feel a very substantial increase in power unless you are running 100% meth. The main purpose of the methanol/water injection is to act as a chemical intercooler, it will just lower your cylinder temps and help prevent detonation, but it will also increase your octane too while its injecting.
One more thing, where am buying the kit, the steeda representative told me i should see an increase of up to 70hp, is that true?
I dont know about running a 10-11 PSI on a stock motor, but im pretty sure that you wont see a 70 HP improvement from just the methanol. As I said the methanol acts as a chemical intercooler, and I have seen people run 100% methanol, you will have to get it tuned when you run a higher percentage of methanol. The only problem is finding the methanol, and it can be a little dangerous if you want to run just 100% due to its flammability. If you want to run around 50/50 you can actually use the blue windshield fluid they sell at auto parts stores, they are simply methanol and water mixed. Here a website with all the details of methanol injection http://www.coolingmist.com/
jwog666
12-27-2021 08:09 PM
