Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
N20 with full boltons/cams
Old 09-21-2008, 07:03 PM
03greyGT
03greyGT's Avatar
Default N20 with full boltons/cams
Hey fellas, I have a question about running some spray in my 03 GT. I have full boltons and cams with 292rwhp. Basically my next step to making any more power with the motor is heads and digging into the bottom end, which im not quite ready to do. So I was figuring in the meantime Id throw a bottle on it, but im not quite sure how much I can get away with. I know that with a stock motor guys are running anywhere from a 100 to a 150 shot, but being as im making more power on the motor, am i limited? Ive heard that I can take another 100rwhp safely, but I just wanted to run it by you guys that had some N20 experience. Thanks.
03greyGT is offline
Old 09-21-2008, 07:35 PM
Soldier GT
Soldier GT's Avatar
Let me know how it goes because I will be purchasing a Zex nitrous system next month. By next may I intend on buying a set of patriot stage III heads. Since I bought a truck this car has become a hobby to me now. My goal is to get in to the 12's or maybe even high 11's. What mods do you have? I'm curious to see what my rwhp is now.
Soldier GT is offline
Old 09-21-2008, 07:41 PM
03greyGT
03greyGT's Avatar
I have:
JLT CAI
BBK 75mm t.b.
ported stock plenum
intake elbow spacer
ported HPS Hardballr' intake manifold
VT stage 2 cams/ Crower valve springs
UDPs
MAC ceramic LTs
BBK O/R H pipe
Flowmaster American Thunder cat back (dumped)
4.10s in a built rear
aluminum d/s
93 octane tune
Im making 292rwhp/308rwtq. Im itching for more but trying to pay off my truck and move out, so I need some cheap, but safe power
03greyGT is offline
Old 09-21-2008, 07:47 PM
Soldier GT
Soldier GT's Avatar
Have you been to the track? If so, what were your 1/4 mile times?
Old 09-21-2008, 08:43 PM
Embalmer
Embalmer's Avatar
Be sure and use at least one step colder plugs with anything over a 75 shot. Also, 2 degrees timing retarded for every 50 hp is recommended.
Embalmer is offline
Old 09-22-2008, 05:45 AM
STi300whp
STi300whp's Avatar
Nitrous does wonders
STi300whp is offline
Old 09-22-2008, 05:00 PM
03greyGT
03greyGT's Avatar
Ive only been to the track one time with it which was also my first time racing ever. I went 13.6@103 with street tires and a 2.0 60ft. My tuner has a lot of experience with Mustangs and he said with a good launch and dr's it is a 12.40-12.50s car. So well see...
03greyGT is offline
Old 09-23-2008, 07:02 AM
302army187
302army187's Avatar
upgrade your fuel pump, 1 step colder plugs (i use NGK plugs) ALWAYS USE HIGHEST OCTANE PUMP GAS YOU CAN, pull 2-4* of timing, use a wet kit, dont spray below 3000rpm, and id go with a 100shot.
i dont know alot about the 4.6's, but if your making 292hp and 308trq, id guess youll make 390hp and prob 430-480trq on the juice
so as far as "can your motor take it" id be more worryed about your clutch.
302army187 is offline
Old 09-24-2008, 11:09 AM
RiCe_KiLlEr
RiCe_KiLlEr's Avatar
i have all the same boltons you have except i have stage 1 n/a cams and at the time i didnt have my 75mm t/b or upper intake and pullies if i remember correctly i made 275rwhp and 298ft lbs tq. i threw on a nx plate kit 100shot and it has been fine. no problems so far. with the nitrous i made 370rwhp and 420ft lbs tq. i cant remember the exact numbers but im pretty sure thats what it was. spray it and have some fun. you will be ok. I also upgraded to 30lb injectors and a focus fuel pump.
RiCe_KiLlEr is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: N20 with full boltons/cams
