Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-13-2009, 11:01 AM   #1
Armydad
Armydad's Avatar
Vehicle: 98 GT conv
Default Hp calculation
Hey,
There was an equation I used a couple years back to approximate what your HP would be after boost. Does anyone know/remember this. I'd like to know how many ponies my boost will add so as not to go past 400hp.
Thanks
__________________
"Funny thing about weekends when your unemployed...they don't mean quite so much" Primus
Armydad is offline   Reply With Quote
Old 01-13-2009, 05:39 PM   #2
Mustang_NTriangle
I don't know a formula but it is roughly 5-6% per 1 psi. Intercooled or aftercooled will yield more hp but really depends on the tune.
__________________
03 Vert 5 speed
450 rwhp
MMR 800 Built Block
CMS 2.5 Blower Cams
Vortech V2 SQ H.O.
Vortech Aftercooled
12.5 PSI
Sniper Tuned
4 sale - pm me
38lb vortech injectors $150 shipped
21lb injectors $ 50 shipped
Aluminum Intake (replace that plastic intake) $100 shipped
(8) stock Ingition Coils $150 shipped
2004 stock short block 23,000 miles $500
Mustang_NTriangle is offline   Reply With Quote
Old 01-13-2009, 09:59 PM   #3
Armydad
Armydad's Avatar
Vehicle: 98 GT conv
Thanks, that will work. If I come across the equation I will post it.
Again thanks
__________________
Old 01-16-2009, 10:13 AM   #4
Norm Peterson
2008 Ford Mustang
Norm Peterson's Avatar
Vehicle: 2008 GT Premium
It probably involves manifold absolute pressure and standard atmospheric pressure, and there may be an temperature correction as well. Ideal gas law stuff, and a direction to get started in, anyway.
Norm
__________________
08 GT Premium Black/Light Graphite, stick, un-FStock
weenie-EP 626/V6/stick, Prepared just enough, sometimes
Norm Peterson is offline   Reply With Quote
Old 01-16-2009, 03:23 PM   #5
jhdksbva
Vehicle: 01 ford mustang gt
i believe its (boost+14.7)/14.7 x original hp gives you an about hp. theirs a site i found with a calculater on it ill see if i can find it again
jhdksbva is offline   Reply With Quote
Old 01-16-2009, 03:24 PM   #6
jhdksbva
http://www.superchargersonline.com/hp_calculator.asp
Old 01-16-2009, 03:55 PM   #7
Norm Peterson
2008 Ford Mustang
That's probably close enough, though I think if you're being picky that you'd use something a bit lower than 14.7.
WOT in a NA engine does not result in 14.7 psia manifold due to flow restrictions through everything ahead of it (airbox, filter, inlet tube, throttle body, MAF, etc.).
Just to try to put some numbers on this, 4-barrel carb flow ratings were made at 1.5" Hg, or about 0.7 psi. In this case, substitute 14 everywhere you see 14.7.
EFI throttle bodies likely permit somewhat smaller losses than all but the larger carbs, so maybe deduct 0.3 psi and use 14.4 instead.
It looks like their intercooler/aftercooler entry addresses the temperature effect (that you get from the heat of compression).
Norm
__________________
Old 01-16-2009, 06:03 PM   #8
luckythirteen13
luckythirteen13's Avatar
put it on the dyno, itll calculate the hp numbers for you
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 01-17-2009, 07:29 AM   #9
Norm Peterson
2008 Ford Mustang
Yes, that tells you what you really do have after you've built it.
But I think the OP wants to have some idea what he's going to end up with before he buys anything, let alone turns any wrenches. At that stage of the game, knowing that you're going to be closer to (say) 500 than 450 or even 500 vs 400 may be good enough. "Calculating" 481 vs 472 and then using those specific numbers for anything is a waste of time.
Norm
__________________
Old 01-17-2009, 01:01 PM   #10
luckythirteen13
Norm
ah i see. i used to have a program called pc dyno. you enter in your motor size, head style, valve size, runner size, compression ratio, boost level, efficiency of your intercool (if you have one), etc, etc. it asked for everything. we used it when building my last motor and when all was said and done, the pc dyno over estimated hp by only 50fwhp. not too bad for something i downloaded for free.
__________________
boost, calculation, turbo, twin
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
