Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-22-2009, 01:17 PM   #1
superchargedyllwstang
Vehicle: 1999 mustang gt
Default blow through maf??
I have recently installed a vortech v1 supercharger w/ a treadstone air-air intercooler. I currently have a 90mm ford lightening MAF draw thru, and was wondering if theres ways around installing a blow of valve that vents to the atmosphere without swappin out the draw thru for a blow thru
superchargedyllwstang is offline   Reply With Quote
Old 02-23-2009, 01:06 AM   #2
luckythirteen13
luckythirteen13's Avatar
you could vent to atmosphere but every time it blows off your motor will go pig rich (not recommended). in order for the motor to run correctly, if you vent to atmosphere you need a blow through maf
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 02-23-2009, 10:00 AM   #3
avexhype
avexhype's Avatar
Send a message via AIM to avexhype
do yourself a favor and ditch the lightning MAF- draw through setup and get yourself a PMAS blow-through MAF. Your car will run MUCH smoother and you can run whatever bypass/blow off valve you feel like. Trust me, when i first put my vortech on w/o an intercooler the draw through and 90mm maf setup worked GREAT. but after the intercooler everything went to hell and the MAF pegged at 400 rwhp and the car ran very rough and with a bad idle. Switched to blow through and OMG what a difference!!
__________________
Just your run of the mill vortech 2v.
avexhype is offline   Reply With Quote
Old 02-24-2009, 10:59 AM   #4
PRO50SC
The Rogue Mod
1992 Ford Mustang
PRO50SC's Avatar
Vehicle: 92 Notch Procharged!
Send a message via AIM to PRO50SC
Yeah, I run a P-mas blow thru, Much better than a draw though for sure. My car ran so much better after switching over.
__________________
92 LX NOTCH PROCHARGED
DRIVE IT LIKE YOU STOLE IT!!!
ROTM 08/06
11.761 run from 4/4/09
See my Movie
Wheels up!!
PRO50SC is offline   Reply With Quote
Old 02-24-2009, 05:12 PM   #5
Pmass is in the mail!!! thanks for the advice guys, im just gonna disconnect my recirc from the intake side so it makes that niceeeee noise i want.
Old 02-24-2009, 08:55 PM   #6
Default supercharger Q
can i vent a bosch recirc valve to the atmosphere when i get a blow thru?
Old 02-25-2009, 04:50 PM   #7
anyone?.............
Old 02-26-2009, 12:51 AM   #8
Frostbitten
yes u can
__________________
03 GT 5spd
Hellion 62mm w/Flowmaster cat back, DSS ProMod shortblock, ported heads, manley nextek valvesprings, spec stage 3, billet flywheel, UPR kmember with MMR A arms and MMR coilovers, dual 03/04 cobra pumps w/BAP, SCT BA2800, siemens 60lb injectors, sct x3 with speedy dyno tune......532whp/630wtq
Frostbitten is offline   Reply With Quote
Old 02-26-2009, 01:40 AM   #9
luckythirteen13
how many times are you going to ask this question?
and you can vent to atmostphere as long as the vent is BEFORE the maf
__________________
Old 02-26-2009, 05:06 AM   #10
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
I merged his threads!!!
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
air, atmosphere, ba2800, blow, draw, ford, lightning, maf, mass, meter, mustang, pmas, sct, setup, turbo, vent
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
