They can take timing out to lower your hp to a certain extent. You'll lose gas milage like that too though. If you run a 3.6 pulley with that blower it should make about what your looking for tuning it all out.
When you sy run a 3.6 pulley, do you mean stock or with my cams, manifold and bolt ons ?
What kind of boost from a 3.6? Also I have an Anderson power pipe so I may gain 1-2 lbs of boost.
Sorry I'm a little thick when it comes to s/c.
Thanks again
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
"Funny thing about weekends when your unemployed...they don't mean quite so much" Primus
Anytime you upgrade your flow, like heads, you drop boost pressure because your engine can flow more air. So if you have 8 psi on a stock motor and upgrade your intake and heads/cam, your boost pressure will drop. So you need to replace you pulley with a larger one.
__________________
We were born to die, everything in-between is life.
Thanks again
I recommend you go with 3.6" pulley and call it a day. You should have no problems hitting 375-380 rwhp but don't go much beyond that or you will end up like me needing to build a new motor.
Don't even worry about how much boost you make. Your looking for around 350 rwhp so go with a 3.6 inch pulley and it will make that no matter what boost you make.
