Quote:
Originally Posted by dkaar
I had the same problems. For me it was the boost pipe. I had a 90mm MAF on a 3.5" pipe. I had to use a reduced from the maf to the pipe and the air was backing up into the maf. Kind of like a pouring too much water in a funnel. Not sure if that is your problem or not. I got the anderson 4" pipe and have zero problems now.
I'm ignorant, but when you say the 4" Anderson pipe, are you talking about their powerpipe, or do they sell regular 4" piping?
The reason is that mine has a much more mild idle issue, and I have the same setup going from the LMAF to the stock Vortech piping (with the reducer that is probably causing my problems). I would love to get it all uniform, but I don't want to spend $250+ to do it (I know I'm cheap).
Also, is the 4" piping a direct bolt up the the LMAF? Or do you still need a reducer?
