New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-30-2009, 03:25 PM   #1
nkguillen1
Vehicle: 2001 Ford Mustang GT
Exclamation VORTECH V-2 ON 01' GT HELP!!
Have few important questions about self installing the Vortech V-2 supercharger on my 01' GT.
1. The belt supplied does not fit around my water pump pulley no matter how much presure i realease. Do i need a longer belt or does it just have to be muscled on there?
2. Can the mass air flow filter be connected directly to the black plastic air inlet attached directly to the blower or do i need the stock O2 sensor on there?
3. Does anyone have a picture of how this entire kit should look installed so that i can have a rough idea? As i'm sure a lot of you have seen pictures are one thing that the instruction manual really lacks.
If anyone has any ideas on any of these mattersr i would greatly appreciate it. Thank you.
nkguillen1 is offline   Reply With Quote
Old 06-30-2009, 05:30 PM   #2
dkaar
dkaar's Avatar
Vehicle: 2001 Saleen
1) The belt does fit...it is a b!tch to get on. Took 2 people and 90 minutes for mine.
2) An o2 sensor is not related to the MAF. The MAF connects to the air filter and then the intake tube or boost pipe connects to the inlet of the sc. At least that is how I did it.
3) http://i165.photobucket.com/albums/u...r/100_6419.jpg
Right where you see the Steeda boost pipe go into the fender is where the MAF is, then the filter is attached to that.
__________________
429 hp w/Vortech V1
dkaar is offline   Reply With Quote
Old 06-30-2009, 05:40 PM   #3
nkguillen1
Exclamation
Ya MAF and O2, sorry got that mixed up. Good to know that it's just a b**** to get on and they didn't send me the wrong one. Also the bolt that goes in the bottom left side of the alternator. Is that supposed to be such hell to get in to? And how the hell am i supposed to set up the air inlet hoses, like the ones that attach to the big plastic piece.
Old 07-01-2009, 02:07 PM   #4
nkguillen1
Exclamation
What size tap do i use to tap my oil pan, this is the only thing holding me back right now everything else is good!!!!
Old 07-02-2009, 02:28 PM   #5
rthouck
1968 Chevrolet Corvette
My Garage
Vehicle: 2000, Ford, Mustang GT Convertible
Vortech has instructions - follow them - they work. If you dont have them go on the website and print them out.
For pictures - Google images mustang vortech
As for the belt make sure its routed right - it shouldnt be that hard to get on .... Mine comes on and off like any other once the tension is released.
__________________
2000 GT Convertible - 400 RWHP
rthouck is offline   Reply With Quote
Old 07-02-2009, 04:02 PM   #6
nkguillen1
Exclamation
Well if I wouldn't need to ask questions on this site if i didn't have any problems with the instruction manual, thanks for the help.
Old 07-03-2009, 05:58 PM   #7
SILVERJET
SILVERJET's Avatar
Vehicle: 2002 FORD MUSTANG GT
did you buy your kit new or used? the reason i ask is because youmight have some more problems
SILVERJET is offline   Reply With Quote
Old 07-03-2009, 07:04 PM   #8
nkguillen1
Exclamation
No it's brand new, i got the belt problem figured out and everything else pretty much came into place. I am now having one more issue there is one very thin hose coming off of an attachment that is attached to my air inlet. If anyone knows where this hose is supposed to exactly attach to please let me know, I have read the directions and i just can't seem to get the answer i need from there, or at least not in a way i can understand.
Old 07-03-2009, 10:25 PM   #9
AirBrontosaurus
Quote:
I would bet that's a vacuum hose. There is a vacuum TEE near the throttle body that that may have come off of. Take a picture and we can probably tell you exactly where it goes.
AirBrontosaurus is offline   Reply With Quote
Old 07-05-2009, 01:18 AM   #10
Blk003GT
Vehicle: 03 GT vert
yeah vortechs instructions suck
__________________
2003 GT VERT
Vortech V-2 sq-trim with aftercooler|cp pistons|cobra crank|ARP hardware|o/r x-pipe|black Saleens|17" Black bullits|Spec stg 1|h&r SS|SLP LM 2's|Steeda tri-ax|PP 75mm TB & plenum|Steeda LCA's|SCT Xcal3|6000k hids|FRPP 3.73's|305 Nitto DR's
Tuned and Built by Fastlane Motorsports
Blk003GT is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
