New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-04-2009, 02:16 PM   #1
zero2005
2003 Ford Mustang
Vehicle: 2003 Mustang GT
Default Masterpower Ebay Kit?
so i was again considering turbo's as a means to boost my car, and i came across this:
http://cgi.ebay.com/ebaymotors/ws/eB...id=p2759.l1259
its only a partial kit, hot side only w/ a MP T-70 turbo. and its only 1700 shipped? i also read that its only got a "partial" down pipe, which means that i would probably have to go and have an exhaust shop build the rest of it w/ a Y-pipe. If i do that, should i omit buying an O/R H or X, and simply go straight from the Y pipe to my SLP's? (AND remove the stock H w/ cats)
__________________
2003 Mustang GT
SLP LM1 catback
Rebuilt 3650
3.73's
upcoming mods : BBK shorties, Megasquirt II 3.0, Masterpower MP70 turbo...
zero2005 is offline   Reply With Quote
Old 07-05-2009, 05:33 PM   #2
sv650lex
Vehicle: 2001 gt convertible
It looks like it will take a lot of work. Yes you will have to have a custom h or x pipe made, but if you dont have access to a pipe bender and welder it's going to cost a bit to have one fabbed up.
I think the biggest problem will be building the intake for it. If your unable to fab up your own parts, I would hold off and save for a complete kit.
sv650lex is offline   Reply With Quote
Old 07-05-2009, 06:42 PM   #3
luckythirteen13
luckythirteen13's Avatar
the kit doesnt look that bad. you will need to spend about $400 on piping and an IC if you buy through ebay. the downpipe will have to be completed and then go into a y pipe. if you go with this kit you can just run the ypipe directly to your catback. no need for a x or h pipe. the reason for those is to equalize exhaust pressure by mixing both banks. this kit does that before the turbo just like any other turbo setup
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 07-05-2009, 07:37 PM   #4
Frostbitten
you can get a complete On3Performance turbo kit for under $1800 on ebay. It comes with everything and bolts right up all you need is the k member and a arms. You can choose from several different turbos to use for an additional fee. Theres a few guys running them already and have made good power..
__________________
03 GT 5spd
Hellion 62mm w/Flowmaster cat back, DSS ProMod shortblock, ported heads, manley nextek valvesprings, spec stage 3, billet flywheel, UPR kmember with MMR A arms and MMR coilovers, dual 03/04 cobra pumps w/BAP, SCT BA2800, siemens 60lb injectors, sct x3 with speedy dyno tune......532whp/630wtq
Frostbitten is offline   Reply With Quote
Old 07-05-2009, 07:44 PM   #5
fordchuck
Yeah, I would look into the full kit to save you some time and initial cost.
__________________
-2006 Mustang GT convertible: intake, tuner, straight pipes, rollbar, blackout panel, front lip, and 20" wheels
-2003 Hyundai Tiburon GT: Eaton supercharger, Cobra exchanger, I/H/E, Apexi AFC
-2009 Mazda 6 GT: tinted windows and front signals, AutoExe springs, and Rotora BBK.
fordchuck is offline   Reply With Quote
Old 07-05-2009, 08:50 PM   #6
zero2005
2003 Ford Mustang
on3 performance's kit may be complete, but from what i can tell this exhaust piping seems beefier and will likely last longer. cold side will be done with ebay "intercooler" piping, with an Air/Water intercooler. at the very least, this thing comes with a 1 year warranty vs the on3 kit, afaik they still dont offer a 1 year warranty?
as far as fabbing up the exhaust -- the down pipe is basically a turn down pipe with v-band. i asked a shop how much for a fabbed up pipe, they said depending on how many bends and welds, probably anywhere from 200-400$ but cant give an exact price until he looks at it.
i already have a full QA1 coilover front suspension.
__________________
2003 Mustang GT
SLP LM1 catback
Rebuilt 3650
3.73's
Old 07-05-2009, 09:09 PM   #7
luckythirteen13
the on3 kit uses low grade stainless for their hot side. they also ripped off b&g's design....at least when it comes to their 5.0 kits
think about it logically, a complete kit for $1800, you know your not getting top of the line stuff
__________________
Old 07-06-2009, 01:00 AM   #8
zero2005
2003 Ford Mustang
yea, i've read about the cheap quality of the on3 kits. thats why when i saw this ebay kit it caught my eye cuz i've seen other kits with pipes beefy like that that have held up to the tests. im still doing my research too, and i dont expect it to be of hellion or HP performance quality but i figure for 1600$, at the very least i get a 600$ turbo out of it. figure i'll be the one to test out this kit since noone seems to have it. just gotta get the wifes approval first. of corse, even if i ordered it now, i wouldnt be able to put it on until December or January due to my upcoming training.
one of the things that looks kind of odd is the fact that, it mounts the turbo in the front, but it looks like it routes the driver side exhaust manifold around the back, and merges into the passenger manifold, THEN into the turbo? trying to think about the back pressure issues there...
__________________
2003 Mustang GT
SLP LM1 catback
Rebuilt 3650
3.73's
Old 07-06-2009, 02:48 AM   #9
Frostbitten
stainless steel is going to hold up to the elements wheter if its aircraft quality or not. That hotside looks like something a guy may have done in his garage at home and is selling it because there was too many issues. probably upgraded to a hellion kit
__________________
03 GT 5spd
Old 07-06-2009, 12:22 PM   #10
zero2005
2003 Ford Mustang
the problem i've heard with the on3 kits mainly isnt holding up to the elements, its that after repeatedly being heated up, the stainless expands and contracts so much that it ends up cracking. that could probably be easily fixed if a small flex pipe was put on tho?
__________________
2003 Mustang GT
SLP LM1 catback
Rebuilt 3650
3.73's
05, 46, cracking, ebay, exhaust, gt, headers, hotside, kit, mmr, mp, mustang, on3, on3performance, pipe, t70, tiburon, turbo
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
