Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
question on nitrous cams
Old 01-20-2003, 07:19 PM
DougBlevins
DougBlevins's Avatar
Default question on nitrous cams
<font face="Arial, Helvetica, sans-serif">i have a NOS wet kit on my 5.0 and am fixing to be ready to buy a cam. i was wondering if anyone had a nitrous cam and could answer some questions for me. like if the nitrous cam only benifits when nitrous is being sprayed into the engine or all the time. thanks. </font>
DougBlevins is offline
Old 02-17-2003, 01:25 AM
lloydchristmas
lloydchristmas's Avatar
You'd be surprised how much power the stock cam can make...
lloydchristmas is offline
Old 02-18-2003, 01:18 AM
noslow50
I ♥ Acer
noslow50's Avatar
NO NOS?????BADDD
noslow50 is offline
Old 02-18-2003, 07:35 PM
lloydchristmas
i think Crane has an 800 # you can call and tell them what you have and then they select or even grind a cam for your needs. I'll look it up and post it later.
Old 02-18-2003, 07:50 PM
lloydchristmas
Its comp cams-- 800-999-0853 if they cant help you nobody can
Old 02-19-2003, 02:10 PM
DougBlevins
how much is it to get a custom grind cam from comp?
Old 02-19-2003, 07:54 PM
lloydchristmas
I bought a custom grind for a chevy motor I was building (for someone else) lol and it was like $240 or something close to that.
Old 03-08-2003, 09:45 PM
red347
red347's Avatar
Most tuners will tell you that a cam with a bit longer exhaust duration work better for N2O engines. For example, I run a solid roller .696/.683 and @.050 it has .278/.286 duration. The lobe seperation should also be a bit wider. 110-112 is preferred for a nitrous cam. This is because a nitrous engine receives such a lot of fuel and oxygen because of the supercooled high density intake charge. This also has an impact on compression, but not too any major degree. So.. a bit longer duration and opening the exhaust valve a bit earlier is key. The drawback? N/A the car will not not perform as well. So you have to choose up front. N2O or no N2O.
Comp Cams makes a wide selection of off the shelf N2O cams, but if a custom solid roller, you might spend $350.00 to $450.00.
Mine is off the shelf. $300.00 Works well.
Ron
red347 is offline
Old 03-10-2003, 03:11 PM
spike306
spike306's Avatar
damn red, 9.74@137mph. that's bad ***!!! are you n/a, blower, or nos?
spike306 is offline
Old 03-10-2003, 06:37 PM
lloydchristmas
Reds car is GANGSTA as hell
Quick Reply: question on nitrous cams
