I have just put a Paxton 1200 supercharger on my 65 coupe, with a 302W. Runs real good but I am getting a small oil leak through the intake when I give it a boot full. It drops on to the belts and goes ape. I am running a PCV valve and thinking this may have something to do with the pressure in the block. Should I remove the PCV Valve and put a breather on the rocker cover instead, or what could the problem be?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
1965 T code coupe.
Paxton 1200 Blown 302W
RRS Rack and Pinion
C4
Heidts four link/sub frame/chassis stiffner
EZ Wire harness
The oil leak is where the the inlet pipe (the one the filter is connected to) goes into the supercharger unit at the rear. It appears to leak only when I give it a gut full and I end up with oil drops on the belt and then it goes everywhere. So I guess just get a breather on the rocker cover and plug the hose.
__________________
1965 T code coupe.
RRS Rack and Pinion
C4
EZ Wire harness
get rid of the pcv and see if that takes care of your oil problem. i had a similar issue when i first put a sc on my car. had the pcv hooked up and the oil was getting blown into the intake. from there it ran past the tb, down the discharge pipe and into the sc and then out the inlet of the sc. ditching the pcv fixed the oil issue for me
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
Okay so tell me if this the right way to do it on a 302W. Just cap the hose, remove the valve and then put in a breather in its place on the rocker cover.
__________________
1965 T code coupe.
RRS Rack and Pinion
C4
EZ Wire harness
Okay got rid of the PCV and put a hose from the pcv location to the back of the air intake on the supercharger unit. Seems to have fixed it. Breather also on the other valve cover.
__________________
1965 T code coupe.
RRS Rack and Pinion
C4
EZ Wire harness
I have a 1970 Dodge Challenger i'm looking at getting a paxton 1200 kit for. Have you had any issues. How is the drivability ? What card did you use ? Also how does the supercharger itself sound at idle and cruising. Is it loud enough to know you have it on there ? I want mine to make some noise like a procharger, etc. Thanks
