the hangers for the tips are made to bolt on to an L-shaped bracket and it is adjustable, the only problem i had with mine was that the drivers side pipe at the end wasnt bent enough so the tip was facing down, i fixed this by sticking only a little of the pipe in it(maybe half inch) and used a self tapper srew to hold it then put the clamp over it.I like the ss pipes but they are almost impossible to bend by hand so thats why i did it with the self tappers, but they sound great and look great.
Alright. Thanks for that info. I'll have to look for that when I get mine. Hopefully nothing is too bad since this would be my first exhaust install and I'm hoping for minimal problems.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
one more thing i had to do since i was doing by myself, after everything was bolted up i put a jack under the h-pipe and lifted it up higher then tightened bolts up more,also make sure you get a saw-all and some metal blades because the old exhaust never comes off easy
Ok thanks. Yeh I have access to some pretty good tools and a car lift which I think will make it easier. Which is one if the reasons why I am going totry and do it by myself.
Oh yeah I will. Decided to just go with the cat back for now. Hopefully have it on in a few weeks. Another topic I'm posting in right now, the guy said I didn't need to update my tune with just a cat back. I ordered the x3 not too long ago with just the 3 brenspeed tunes for a stock car. Do you know if it would be worth it to pay the money and get one ofthe tunes updated for the cat back?
I really don't think you'll need a updated tune for the cat back.
__________________
2004 DSG Mustang Gt, BBK long tubes, BBK catted h pipe, SSS Terminator Catback, K&N cai, Steeda UDP's, Accufab 75mm tb/plenum, FRPP aluminum ds, Motive 3.90 gear, Alternative Auto custom tune, Steeda Tri-Ax, DD black bullitts w/315's Nitto 555R's, & 100 shot N20. 269/305 na, 373/528 N20
+1...i should've metioned this as well. I pretty much did the same thing.
__________________
Was that beause you were installing an after market mid pipe or to get it closer to the body of the car for clearance
i did that because there are no hangers close to the mufflers so when i was all done it hung down by the h-pipe, so i loosened it up jacked it up and retightened,if you had two people then just have somone hold it up by the axle and then tighten
