Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-03-2009, 01:39 PM   #1
rdsx18
2005 Ford Mustang
Vehicle: 2005 Mustang GT
Default Exhaust leak?
So I just installed headers and a catted x-pipe and it sounds like I have an exhaust leak. I don't know how to describe it, but it is coming from up front and it only happens at ~1/2-full throttle. Is it normal to sound like this or do I indeed have a leak? What is the best way to check for a leak? I had my father hold some rags in the exhaust pipes while my brother gave it some gas and I couldn't hear any leaks. What else should I try?
__________________
2005 Redfire GT
rdsx18 is offline   Reply With Quote
Old 10-04-2009, 10:45 AM   #2
rdsx18
2005 Ford Mustang
Nobody? I guess I could describe the sound as more of a wooshing sound, not like the ticking or popping noises I hear from other cars with an exhaust leak. Is that normal with an x-pipe?
__________________
2005 Redfire GT
Old 10-05-2009, 12:34 PM   #3
rdavin622
1995 Ford Mustang
rdavin622's Avatar
Vehicle: 1995 Mustang GT-S
I installed headers and a BBK catted H-pipe and my car makes a similar noise. Kind of like a car with no mufflers, or a huge exhaust leak sound from inside the car. I dont have any exhaust leaks at all
rdavin622 is offline   Reply With Quote
Old 10-05-2009, 01:04 PM   #4
rdsx18
2005 Ford Mustang
Quote:
Ok I can hear this when I drive by walls too or under bridges though. I got under the car and tightened up where I though it came from, had my dad cover the tips while my brother gave it some gas and it sounded gone. Drove to class and it was fine, drove home and it came back. Idk what it is now.
__________________
2005 Redfire GT
Old 10-05-2009, 05:43 PM   #5
rdavin622
1995 Ford Mustang
rdavin622's Avatar
I know what you mean my car does the same thing. I thought I had an exhaust leak but it was just the unique sound that the BBK headers and H-pipe make. The factory exhaust is designed to be quiet and not to disturb the peace. I think its just more exhaust flow and its noisy thats all. I could be wrong but thats what happened to me.
Old 10-05-2009, 06:07 PM   #6
rdsx18
2005 Ford Mustang
I know what you mean and you are definitely right. I just got done tightening everything up again and had my dad hold rags in the tailpipes while I listened and felt under the car. It was dead silent under there and I couldn't feel any leaks at all. I don't mind the noise I just wanted it fixed if it was a leak. Thanks for the help!
__________________
2005 Redfire GT
Old 10-05-2009, 06:46 PM   #7
zanypunk
Does it sound like a ticking noise? It you can hear it better if you're in a garage. It's exhaust leak and you test with a smoke machine. You put smoke from the tailpipe and see if it has leaks. I have one at my workplace and makes life so easier. Small leaks are okay but if it gets loud... Well you will lose performance and your gas milage will suffer. I can go on and explain the causes it will bring but you get the idea.
zanypunk is offline   Reply With Quote
Old 10-05-2009, 07:17 PM   #8
rdsx18
2005 Ford Mustang
No ticking noise, and I was in my garage, couldn't hear or feel a thing when I was under the car while it was running.
__________________
2005 Redfire GT
Old 10-08-2009, 05:50 PM   #9
zanypunk
Good! Most noise leaks are noticeable when the engine is accelerated just to let you know though and sounds like a whistling. If it's rattling, then you would have to check the muffler or cats. Oh if it's a wheezing noise at idle or with engine running at higher RPM, check for restricted exhaust. (Don't assume the cats though, this is just reference info) How's your gas mileage though?
Old 10-08-2009, 05:51 PM   #10
zanypunk
cats, exhaust, find, ford, headers, leak, leaking, make, muffler, mustang, smoke, sounds, symptoms, test, tests
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
