Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-09-2009, 09:02 PM   #1
mustang51js
Vehicle: 2002 mustang gt
Default need some help
ok i have a vortech v2 s-trim kit and i had the chip in it that vortech gives you. I went and ordered a SCTX3 with a supercharger tune from blow by racing. I had to change out the mass air sensor because they said stock was to small, so i did that and put the tune in. When i first took it out it seemed to not have the same pick up as it did before like it was bogging down a little,its not doing it as much but now i have a check engine light on which says my air intake temp is to high. What am i sopposed to do, is the bogging from that or do i have to have them retune it, what can i do about the AIT code
__________________
02 black gt,vortech sc,3.25 pulley swap,air to air intercooler,anderson powerpipe,3.90 motive gears,aluminum drive shaft,75mm tb,75mm trick flow plenum,38lb injectors,lowering springs,cobra rims front 245/45/17 rear315/30/17,summit racing o/r h-pipe,sss terminator cat-back,CHE LCA'S, Ford racing UCA's. 90mm lightning maf and sctx3 tune
mustang51js is offline   Reply With Quote
Old 10-09-2009, 10:39 PM   #2
luckythirteen13
luckythirteen13's Avatar
i would never run a mail order tune on a boosted motor.
what you should have done is, taken the vortech chip, thrown it in the trash and took the car to a dyno tuner immediately after the sc install
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 10-09-2009, 11:34 PM   #3
mustang51js
i will but theres nothing close to where i live, Blow by racing said there tunes were close to a dyno tune so i figured i'll try it out but at least i have the sct tuner to use.
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
