Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-15-2009, 02:06 AM   #1
FLYBOY_GT
FLYBOY_GT's Avatar
Vehicle: 99, GT stang
Default Super Charger Help
Hey all, so Im traveling down the road of the 1500 dollar supercharger kit, i bought a Vortech V1 for CHEEAAAP the kicker was that it needs a new impeller, question is which impeller can i put in it? Ive only been able to come across one website, www.superchargerrebuilds.com, that sells the impellers and they offer an A trim and an S trim, Is there anywhere else i can find them? and last one, what is the difference between A and S trim?
thanks for all the help
Geoff
FLYBOY_GT is offline   Reply With Quote
Old 10-15-2009, 02:58 AM   #2
FoxGT
Vehicle: unicycle
Send a message via AIM to FoxGT
I would double check with vortech on the impeller options. The trim will effect the efficiency at a given pressure ratio & air flow vs impeller speed. The A trim won't flow as much as the S trim. Ideally you want a trim that will suit your needs. It's best to figure out your hp goals, then figure out the air flow & pressure required from the s/c to get to those goals, then pick the trim. You need to keep in mind though that changing the trim will mean that your impeller will be changing size which means your compressor housing won't work anymore unless it was designed to fit that trim.
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
FoxGT is offline   Reply With Quote
Old 10-15-2009, 05:15 PM   #3
Frostbitten
you need the s-trim impeller
__________________
03 GT 5spd
Hellion 62mm w/Flowmaster cat back, DSS ProMod shortblock, ported heads, manley nextek valvesprings, spec stage 3, billet flywheel, UPR kmember with MMR A arms and MMR coilovers, dual 03/04 cobra pumps w/BAP, SCT BA2800, siemens 60lb injectors, sct x3 with speedy dyno tune......532whp/630wtq
Frostbitten is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
