Intercooler tech Question - from Iraq - Why is the a square hole on the top?
Ok so I'm guessing this will be an easy one for someone - or possibly everyone. Anyway I'm assembling the parts to intercool my mustang from Iraq - just bought the intercooler - It has a square hole with mounting tabs around it. What goes there? or what plugs this hole?
Its hard to figure this out from Iraq so I'm hoping this is any easy one.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Its an air to air - all the other pieces sticking out are plugged and only for mounting. Its just this square hole in the top thats open - I've never seen it before....
I posted 2 more pics of it.
If I have to I guess I can machine a piece of aluminum with an o-ring groove or something to seal it but I'd really like to know what this is for.
maybe its some sort of boost gauge screw on thing, ive never seen that either
__________________ 02 black gt,vortech sc,3.25 pulley swap,air to air intercooler,anderson powerpipe,3.90 motive gears,aluminum drive shaft,75mm tb,75mm trick flow plenum,38lb injectors,lowering springs,cobra rims front 245/45/17 rear315/30/17,summit racing o/r h-pipe,sss terminator cat-back,CHE LCA'S, Ford racing UCA's. 90mm lightning maf and sctx3 tune
i just watched a video on u-tube and they had a intake for a new camaro, it had the same holes in it, i believe your holes are for a mass air sensor
After further research into Camaro sensors I think thats definetly it. Thats explains why we were all stumped.... Guess I better get it cut off and welded shut before the Camaroness contaminates my garage....
