Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-26-2009, 10:53 PM   #1
Psustu
1999 Ford Mustang
Vehicle: 1999 Gt Vert
Default Car is stalling when I come to as stop, after boost.
THe Iac is only 1 year old. When I get on it, and come to a sudden stop, Idle jumps a bit, and car shuts off. Starts right back up, but this is dangerous. I was going to make a turn onto the highway, and car shut down, could barely turn in time.... Is it the BOV or the tune? Thanks
Psustu is offline   Reply With Quote
Old 10-27-2009, 01:13 PM   #2
EODMustang
2001 Ford Mustang
EODMustang's Avatar
Vehicle: 2001 Ford Mustang GT
I've been having the same problem for awhile now. I'm running a Hellion single turbo setup and it seems like every time I get on it hard then let off all the way or brake immediately, the car dies. I've been trying to figure it out for awhile now. I have a couple ideas of what it could be. I thought it might be because the IAC, even if it's working properly, can't compensate for such a larger volume of air moving through the intake piping and then it dropping off quickly when you let off the gas pedal. To fix it I thought about making the setscrew on the throttle body stick out a little farther to keep the butterfly open a little bit more at idle, then disconnecting the battery to reset the idling parameters in the ECU, then letting the car sit and run for about 15 minutes to re-learn the idle. I figure that this might take some of the burden off of the IAC to properly idle the car by letting a little more air than normal flow through the throttle body itself. Maybe somebody on here can give us a little bit more of a concrete answer than just my speculation
EODMustang is offline   Reply With Quote
Old 10-27-2009, 03:18 PM   #3
silverscmustang
silverscmustang's Avatar
Vehicle: Awaiting next Ford :)
that happened once on my old V6, good thing I got rid of it lol
__________________
Previous Cars:
2005 Mustang V6
2005 Mustang GT
Current:
2007 Roush Nitemare #58 out of 100
silverscmustang is offline   Reply With Quote
Old 10-27-2009, 04:36 PM   #4
Frostbitten
that is common with a draw thru setup on these cars. happened to me with a vortech kit and the hellion kit. both setups were done by different tuners. Finally I found a tuner that knows what hes doing at Speedy Dyno. He tuned my hellion kit and I have not once died. I told him about it before he started tuning and he knew exactly what i was talking about. The only thing he told me that he did different was raise the idle rpm a little bit. I think he increased it 50rpm
__________________
03 GT 5spd
Hellion 62mm w/Flowmaster cat back, DSS ProMod shortblock, ported heads, manley nextek valvesprings, spec stage 3, billet flywheel, UPR kmember with MMR A arms and MMR coilovers, dual 03/04 cobra pumps w/BAP, SCT BA2800, siemens 60lb injectors, sct x3 with speedy dyno tune......532whp/630wtq
Frostbitten is offline   Reply With Quote
Old 10-28-2009, 11:31 AM   #5
rthouck
1968 Chevrolet Corvette
My Garage
Vehicle: 2000, Ford, Mustang GT Convertible
Sounds like you're just getting blower surge to me. Are your by-pass valves the correct size and properly installed. If they're adjustable are they adjusted correctly?
If the problem is when you're getting off the gas - (and it runs fine any other time) sounds like blower surge.
__________________
2000 GT Convertible - 400 RWHP
rthouck is offline   Reply With Quote
car, shuts, stalling, stop
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
