i went to install the steeda oil separator and in the directions it showed going into the valve cover on the drivers side, i must be missing a peice because none of them fit into that hole its to big, so my question is can i install it on the same line that goes to the intake from the drivers side valve cover, just cut it in. The only thing is i think that line is bigger than the supplied line, but i could hose clamp it down, i would think this would work because its the same hose just installing it in the middle of the hose instead of right out of the valve cover.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________ 02 black gt,vortech sc,3.25 pulley swap,air to air intercooler,anderson powerpipe,3.90 motive gears,aluminum drive shaft,75mm tb,75mm trick flow plenum,38lb injectors,lowering springs,cobra rims front 245/45/17 rear315/30/17,summit racing o/r h-pipe,sss terminator cat-back,CHE LCA'S, Ford racing UCA's. 90mm lightning maf and sctx3 tune
i have one allready just seeing if i can put it between the line off the intake from the vortech that goes into the top of the drivers side valve cover
