Quote:
Originally Posted by AirBrontosaurus
The V-1's get a lot noisier as they age. How old is the charger? Do you hear any uneven noises or grinding/rattling that could mean internal problems? How does your car drive when the whine is present?
Its about 4-5 years old. I sais a V2 on the label actually but its not the SQ version. I forgot what version blower it is. Its got bunch of serial numbers. Its sounds normal while at hot temperatures but about 4 month ago I noticed it started to sound a little different for 20 seconds after start up then about 1 month ago it started to squeak for about the same time. Before all that It used to be quiet until the blower warms up then the normal whine would come out when the rpm would drop to usual range after cold start up. I am going to disconnect the return line and see if enough oil is coming out maybe its the oil pressure problem. I also drive the car once a week and don't turn it on during the week maybe it has something to do with that.
