they might...you need to check some stuff tho.
make sure the pattern on the mufflers is the same (offset/offset or center in/center out or center in/offset etc....)
check the pipe diameter of the mufflers you have and the mufflers your getting.
check the overall length of your mufflers
if everything above is the same they wil fit just fine. if the new mufflers are too long or a little short...youll have to get an exhaust shop to fix it but they can make it work easily.
__________________
mustang wasnt fast enuff so...
Newest Mod:
2008 Yamaha R6
