So i have 2 stock vortech bov's,could i run one right after the other in line or am i better off getting a new one.Right now my car sounds like the one in the vid and my boost gauge jumps up and down,all this is below 3000rpms because i havent got a new tune yet, i go tomorrow for that but im still going to take it easy at first until i know im safe.
Yes. There is nothing wrong with running two beside eachother. It keeps cost down. Ideally you want them as close to the throttle plate as possible unless it will be venting metered air. Also keep in mind, some single chamber bov's will sometimes make that noise at low boost due to not having enough pressure to overcome the spring. If it still does it at higher rpm, i would add the other one.
