#05130nos kit on 98 gt
There is a guy selling this kit for dirt cheap. It is the universal wet kit for 4 and 6 cylinder cars. would it work with my car it's a 98 GT? what is the difference between this and the 5131nos kit which is the universal kit for 8 cylinders? Thanks
Usually, the main difference between the 6 and 8 cylinder kits is the amount of spray, both nitrous and fuel (since it's a wet kit). Most of the generic kits use the same solenoids and lines, so you should be able to swap out both jets (or at least the fuel jet to richen it up).
One piece of advice when using nitrous- keep the bottle temperature as stable as possible.
hp rating ... so the selonoids are smaller in the small kit.
that kit will spray 35-50-75 pretty sure, where the bigger kit is 75-100-125
the smallest selonoids i am aware that NOS makes are "super powershot" you could spray them up to about 100, so i see no reason why you could't squirt 100 on those selonoids.... just not sure if the fuel selonoid is good for it. i always squirt dry
how cheap is "dirt cheap" ?
if it's 200 you can't go wrong.... jet it to 75 and call it a day, you'll knock off a full second and get 15 runs per bottle... 125 jets might only get you 1.1 seconds and 8-10 runs max
the first second is the easy one to get
One of the problems you might run into is that some of the lines may not be the correct length, due to the fact that it's supposedly universal, and not specific. I had this happen to me. But if it's an awesome price you can replace things pretty cheap, and still come out ahead.
jwog666
12-27-2021 08:09 PM
