Roush exhaust question about x pipe
12-29-2009, 01:30 AM
OK, i have a stage one Roush with the aftermarket Roush exhaust. I love the way it sounds and the deep tone it creates. But, i wish it was a little bit louder. I was wondering if i installed a x pipe would it make my tone any different? I don't want the tone to change, just loudness. I also dont want the car to sound like a monster truck or a nascar if i added the pipe. Just louder exhaust.. ANY HELP?? Hopefully it makes sense.
12-29-2009, 09:45 AM
Banned
What year do you have? I would stay with an H-pipe to keep the low tone. An X-pipe will give you a higher pitch/raspy tone.
12-29-2009, 11:24 AM
The x pipe will change the tone to a smoother, higher pitched sound. I would personally stay with the h pipe, or just go with a different muffler that's somewhat similar to the Roush one.
12-29-2009, 12:27 PM
ok thanks, so would it be worth getting a new h pipe? or is the stock pipe basically the same?
12-29-2009, 12:33 PM
Well, if the h pipe that you have now is catted, then it would be worthwhile to switch to a o/r h IMO.
I'm not sure how the Roush exhaust is setup exactly.
12-29-2009, 12:35 PM
I believe the pipe is catted. But if I switched to the o/r then i would have trouble passing emissions test wouldn't I?
12-29-2009, 12:52 PM
As far as emissions go, i hear mixed things. We don't have it here in MI, so i couldn't tell you personally. I know it varies state to state.
If it is a problem, just keep the stock h, and swap come test time.
12-29-2009, 03:03 PM
Ok, ya im in texas and they are pretty strict on emissions. Ya, that is probably the only way that it could pass.
12-29-2009, 05:40 PM
if you want to pass smog you need to keep the stock h-pipe or go with a high flow catted h-pipe. the high flow setup will allow you to still pass emissions and will make the car a little louder
02-05-2010, 10:31 AM
Did you end up buying the H pipe or did you get the x pipe? i am having the same dilema with my exhaust. I am not sure if should get the x or the H for my Roush stage 1. Can you let me know?
