blow thru maf..help please
There is no mechanical difference between a blow thru or draw thru maf. Its all about where its mounted. The best setup for a blow thru design pushing that much power is gonna be a VMP maf housing (preferably 75mm or whatever diameter the rest of your intercooler piping is to create less air turbulence), and a 05+ slot style sensor. For the sensor, I'd recommend the PMAS HPX slot style sensor. You're also gonna need a wiring harness to use the newer style MAF.
And no need to run around and look, I have the link right here.
http://www.vmptuning.com/store/index...=234&parent=29
bradleyb
11-27-2015 07:50 PM
