Vortech SC ? Best Pulley Size for my setup.
Also can I use the Stock Vortech Bypass Valve with the New FMIC..
Adding a FMIC.. 32X12X3.. Would like to go lower on the pulley, and get a way more aggressive tune, now that temps will be down..
Hoping for 390 ish..
MY MODS::::::::::::::::::::::::::::::::::
Vortech V3 Si
Anderson Power Pipe
90mm SCT Mass Air
42 Lb Inj
3.73
Mac Prochamber
Flowmaster American Thunder
KB Boost a Pump
C&L Upper Plenum
BBK 75 mm TB
Focus 255 fuel pump
3.60 stock Pulley Now making 357/ 358 HP TQ
Vortech V3 Si
Anderson Power Pipe
90mm SCT Mass Air
42 Lb Inj
3.73
Mac Prochamber
KB Boost a Pump
C&L Upper Plenum
BBK 75 mm TB
Focus 255 fuel pump
3.40" or 3.33".... im goin with the 3.40" and i have the 24x13x3.5 core which should put me close to 10 psi..... your core is abit bigger so maybe the 3.33" for you.... might wanna call vortech though....
what kinda fmic are you using? I used a CXRacing and had to go down to a 2.95 to see 12lbs. I had a 3.33 on there initally and only saw 7 lbs after I installed the intercooler. Saw 10lbs with a 3.60 pulley b/f intercooler install. Also you are going to want to upgrade your bypass valve to something that can move more air. If you dont you will get some mad compressor surge, and thats not good.
CXRacing.. Yeah I make 10 lbs now Non IC..
I want to get back up to around 10-11 again.. What Kind of power are you making with the intercooler? Any suggestions on the Bypass Valve. Thanks Bri
definitely upgrade the bypass or you most likely will get surging. As mentioned above the Vortech mini race is a real nice unit. I ran it with my old setup which was 390/402 and I am running it for my new build. I ran a paxton front mount, power pipe, vortech mini race, and a 3.12 and I was seeing about 12-13.
09-16-2015 07:53 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
