Blow through carb?
Blow through carb?
I'm going to be installing a 70mm single turbo and have a few questions. First off is about blow through carbs (it's going to be a carb setup). What would you recommend for a carb... I'm starting probably around 6-7lbs of boost on a midly built 351w. Can I use my standard 750cfm I have now or do I def need a blow through? Also what bonnet would you guys recommend?
bradleyb
11-27-2015 07:50 PM
