vortech winter help!
http://www.wolverineheater.com/products.shtml
what do you guys think about me rigging something up so that I can heat up the blower 10-15 minutes prior to start up during the winter? the pad will pretty much be placed on the backside of the blower, hooked up to an AUX power outlet (key/power on/engine off), and then start it up safely once it's nice and warmed up enough.
Obviously I'll disconnect the power during the summer and zip tie the cord safely away from sharp/rotating parts.
Looking at the model 9 or 16. The vortech is a "torqueless wonder" so even with 480whp (intercooled), it's a pup under 2800 rpm so it's all good during winter driving...
for those who do not have a Vortech, the winter warning is pretty much to warm up the blower for 10-15 minutes via heating blanket or garage and use a small shop light placed over the blower over night. Engine block heater does nadda since it's a self-lubricated kit. If instructions are not followed, the blower destroys itself on start up.. the EXACT moment of start up! Being in Anchorage Alaska, it does get down to -25 on occasion..
help!
help!
Where did you hear about the blower destroying itself in the cold? I seem to remember reading the manuals pretty closely and I don't remember that part.
Not calling you a liar, I just want to make sure I didn't miss anything important.
http://www.moddedmustangs.com/forums...erlands-2.html
heres one of the threads from another sites. on the v3 kit, it was on the flier that was with the envelope for the warranty. I'll see if I can find it later...
you drive your car in temps lower then 25*? f*ck that!!
seriously tho, if you let the car come up to opperating temp, the blower will warm up too. keep in mind, any time its spinning, making boost or not, heat is made. friction exists at all temps and loads. not to mention the fact that the motor is heating the engine bay, which is where the sc just so happens to be
I thoght that too, but if you look at a cutaway pic of the supercharger, you will see that the gears inside are configured in a way that is very exact and tight fitting against one another. In extreme cold weathers, these clearances change and those changes destroy the blower at the exact moment of start up.. so I have been warned. Ah, this will be the last year with the Vortech anyways... I'll most likely get rid of it next summer.
regardless, vortech says they will NOT cover the damages and its not under warranty if it does blow up..
