paxton/vortech 8" crank pulley
i have a 6.78" crank pulley and want to upgrade to a 8".....
problem is the s/c belt with the 6.78" pulley is already really close to my water pump pulley. i really think the belt on the 8" is going to hit...unless 8" is spaced different. idk
has any one have any experience with this on a fox body 5.0
un less is spaced just alittle different..... and no one can give me a straight answer vortech says o know it will work only differences is its 8inch... in my case i dont see how is would work.
would you happen to have a pic of a 93 cobra water pump pulley on a motor
you have a picture of the sc belt tensioner? one not so zoomed in?
the reason i ask is because i remember when i had a v1 the idle pulley bolted to a bracket. that bracket had two holes in it. if you attach the pulley to the lower bolt in that bracket, itll lower the point the belt runs up to. this may give you a little more clearance. id also like to see how close the belt is to touching itself as it wraps around the tensioner pulley
