Spray with low compression
I wanna throw a 100 shot just to screw around with for now i was wondering what i need to do to make it work. I have 8.5:1 compression im running the stock heat range for plugs and my mods are in my sig. Do i need to change my plug gap? If i run colder plugs they foul out with the stock compression. So im just looking for advice for what i need to do to make it work.
Thanks
Thanks
15 psi AND another 100 of smack ? i think your pushing your luck personally. 50 on a blower will act like almost 100 on a NA car, but hey... i dont blame ya for trying
but your fine as is. i use stock plugs gapped at .042" on around a 100 shot kit
haha... oh yeah spray away. up to 150 no sweat at all. i ike to stay jetted around 80-100 cuz those are the biggest gains. the et you drop after that compared to how much quicker you run out isnt worth it imo
the first 75-ish is good for about a second depending how your setup. the second 75 if you sprayed 150 might only knock off another .3-.5 but use twice as much nitrous
but you see how it does for your car. 80-100 for sure... then play with the jetting and see what you get
jwog666
12-27-2021 08:09 PM
