Pipes, Boost & JuiceTalk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Welcome to Mustang Forums!
Welcome to Mustang Forums.
if you double the temp of a cylinder you double the pressure, so on those chilly nights you might have half the bottle pressure. the most ive seen from a full bottle is 1200 psi, and if you cut that in half your now in the innefective range of bottle pressure
purge...no, its cool, but not necessary really other than consistency, and i run cheater slicks so im better with no purge and a softer hit
you can exit anywhere.....IMO you might as well go str8 up at the windshield....intimidate the b!tche$
__________________
'93 calypso notch 6th stang and counting
nitrous oxide is proof there is a GOD and he wants us to be happy
yes i run 2 switches, one for the system and 1 for the heater
et streets hook EXTREMELY well, radials or bias ply no matter. enuff that if you heat them good enuff....you dont even know you dont have slicks. i do a mild burnout cuz my axles are still stock. heat them til they haze....ease out...launch about 3500, no lift shifts
NO NITTOS !!!!! ive used h rated street tires that hooked better
et streets or hoosier quick time pros....thats all i'll use
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware
corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford
Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor
Company
